Does anyone know where these wires go?
I was poking around the engine compartment and found these three loose wires tucked underneath the carburetors. Someone wrapped clear tape around them, and labeled them "A/C", so I assume I will eventually need to reconnect them to get the air conditioner working, although that's probably a year or two down the road. They come out of a wire bundle that runs under the glass filter bowl. Wondering if anyone has insight into this. My car has A/C, which I'm guessing was a dealer-installed option.
In the background you can see that I'm part way through replacing the solenoid, unrelated to the current question. I'll post something on what it took to get the car started when I've made some progress on that.
Best regards, Scott
Best regards, Scott
Re: Does anyone know where these wires go?
Don't know.
I can reasonably say that they are not original wires as the Jaguar loom had bullet connectors not spades and the plastic coated wires look too new. Original wiring was predominately cloth covered. But as you have guessed if this is an optional extra for the A/C then it could have any wire and connectors fitted.
Not original as Cass says. Might have run to an idle speed booster when the HVAC compressor clutched in??? You will have to trace.
Cass, Glyn, thank you for the feedback. I'll hopefully come back to this when I get the more immediate issues sorted out. Best, Scott
Just for your information Scott that felt pad you have on the bulkhead behind the battery needs to go. When you open the bonnet on a rainy day water pours down the back of the battery onto this pad which then stays wet for a long time. Being wet and in contact with the metal of the bulkhead you will find it rusts through over time.
I had to make a repair to my bulkhead during me rebuild as it had a great big rust hole in it. I have replaced my felt pad with a closed foam pad which does not retain water but protects the bulkhead from damage should the battery try and move. Please excuse the welding but I was new to it and this was outside in an open area with a breeze blowing.
Cass, thank you for the advice about the felt pad. I pulled it off to see what was behind - fortunately no rust. This car seems to have spent a lot of time baking in the sun, but must have been kept fairly dry.
- IMG_3877.jpeg (3.08 MiB) Viewed 5179 times
Three other places to check.
Inside the rear doors where the chrome window channel is bolted to the inside of the door. Here you will find another felt sound pad. Water runs down the channel onto the felt pad and the door rusts from the inside to out. Very common on a Mk2 and S type. One of my rear doors had been "repaired" before I got to it. They had welded in a small square repair patch which had warped the door skin. Took ages to repair this.
The second place is inside the rear wheel arch. On the inside face against the boot wall there are some scallops just like the shape of the bulkhead behind the battery. These retain mud and moisture and you will get rust through this area into the boot. Same as below the dirt and stones get kicked up and damage the paint exposing it to rust.
Lastly the front leading edge of the fuel tanks. All the detritus from the rear wheel gets kicked up into the face of the fuel tank and causes wear and rust. Sometimes the pin prick holes are too small to actually see the fuel leaking but you have a constant smell of fuel vapour in and around the boot.
The rear door felt patch that pads the bottom of the window channel from the skin is very common. Soak with Tectyl.
Cass, Glyn,
Thank you for the rust advice - I will add this to my (growing) list.
Best, Scott
Best, Scott
Last 100 Members Who Visited This Topic. Total 60 visits
Robbo911 (3),
HG_S-type (1),
member (1),
John Quilter (5),
Glyn Ruck (3),
cass3958 (10),
Rogerisleofman (5),
Treetrimmer (7),
minimeadow (14),
Tom Hoffman (2),
jaguar&mg (3),
jerry_hoback (1)
