Wheel arch liners
paddyx350
Wheel arch liners
Post by paddyx350 »
Was the S type fitted with wheel arch liners at the front or rear?
Just wondering as mine has none. I can tap the underside of the wing if I put my hand under the wheel arch at the front
Chris
Wexford, Ireland
1992 xjs coupe, red
2003 xjr, black
Re: Wheel arch liners
No wheel arch liners at the front above and forward of the tire. Rear fender is double skinned and has a liner.
Eugene, Oregon USA
As John says no liners under the front wheel arches. The underside of the arch is the wing and everything is exposed. There is a plate at the back of the front wheel arch between the floor and the wing which does rust out. If there is any gap in this plate then water can get down in to the sills and the bottom the the A pillar so it is important to make sure this is sealed.
John is half right with the rear arch. There is no liner in the modern sense as it is all metal. If you look at the top of the inner arch there is a seam. From the seem to the outer arch this is a liner of sorts as behind this there is a void which you cannot get to between this liner and the outer wing. From the centre seam going inwards towards the boot this is just a single skin and it has strengthening recesses in the plate like rounded triangles. There are three of them and from inside the boot you can see the corresponding shapes. As the wheel is pretty tight in the wheel arch mud and dirt can layer up inside these strengthening recesses which you cannot see with the wheel in place. If you do not take the wheel off and clean this area it is prone to rust and you will have holes going from the wheel arch straight into the boot.
Also keep the open rear wing bottoms clean around the dual fuel tanks. Mud & muck can build up & cause rusting.
paddyx350
Post by paddyx350 »
Thanks for the information.
Chris
Wexford, Ireland
1992 xjs coupe, red
2003 xjr, black
Last 100 Members Who Visited This Topic. Total 18 visits
Fonzie (1), User avatar John Quilter (4), Treetrimmer (2), User avatar cass3958 (4), paddyx350 (2), RollyTG (1), JCS (1), User avatar Glyn Ruck (3)
