Number 1 is C23210 Front vacuum pipe.
Part 57 plate 88 it is the metal hose that goes between the Brake vacuum reservoir and the heater vacuum reservoir just in front of the bottom of the radiator.
Number 2 is C30074 Air intake hose.
Plate 8 part 18 is the paper hose that goes from the air filter box to the front of the radiator for cool air.
Not entirely sure on number 3 will have to check tomorrow but I think it might be C26482 Mounting bracket for reservoir, which goes behind the PAS reservoir tank on the inner wing so the tank can sit upright and not at an angle against the inner wing. It is not shown in a diagram in the parts book but is listed on page 322 under 69-10
Number 4 is C19425 Reservac tank
Plate 88 part 53 is the vacuum tank for the heater and scuttle switch. Goes under the front left wing mounted on the front cross member.
Thanks again....
Just looked at this part in the manual: Number 2 is C30074 Air intake hose.
Plate 8 part 18 is the paper hose that goes from the air filter box to the front of the radiator for cool air. Rob, do you have part 19, the clamp that secures this hose to the front of the radiator?
That's great. If you have two rubber locating pads that attach to the gas tanks to buffer the tanks. Part 26 on the fuel system assembly. Once you get everything together, please check shipping to 65672. If you have a good vacuum tank add that too. Please give me a list of what you have so I know to look elsewhere for the other parts.
To summarize:
Vacuum Tank (I have the bracket and the screw in valve)
Bracket that holds the paper hose
Banjo
Banjo bolt
Servo clamp
Support block for servo clamp
Shim for servo clamp
They are added to the list anyway.
I have four...just need two.
Thanks
Servo clamp complete with bolts and rubber grommets but it does not have what you are calling the shim.
Two rubber petrol tank pads.
Banjo and banjo bolt from the servon
Complete air hose bracket and clamp.
I do not have a vacuum tank and if I did I would possibly hold on to it baring in mind I might have a hole in mine when I start investigating.
You can buy new ones from David Manners https://www.jagspares.co.uk/product/bra ... /c24910**1*** which is where I might go as they are used on the Mk2 but the other vacuum tank you have for the heater is not made anymore. SNG are £15 more expensive. https://www.sngbarratt.com/uk/#!/Englis ... e5198f518f
I hope the banjo is the one you're looking for. I have attached a photo of it in situ on my old servo to double check.
- IMG_8270.JPG (2.8 MiB) Viewed 9994 times
- IMG_8269.JPG (2.55 MiB) Viewed 9994 times
- IMG_8271.JPG (2.64 MiB) Viewed 9994 times
Treetrimmer (14),
RollyTG (28),
Glyn Ruck (301),
BruceK (1),
gripper (1),
jerry_hoback (2),
Albion (44),
gerrypopO (1),
Norton (3),
Euler (22),
JacobusBrinker (5),
MDLV (1),
Cobrasc10 (1),
KeithD (2),
jaguar&mg (7),
JCS (2),
John Quilter (78),
David Reilly (7),
cass3958 (188),
DevilDog (307),
Sam01 (2),
jonesdl (37),
Orlando St.R (22),
NigelW (22),
XKJag (1),
Tom Hoffman (3),
NWG (2),
Motorvated (1),
dennis (1),
Norrena (6)
