In the process of overhauling the carbs on my 3.8S, and while they are off its an opportunity to do some other jobs while I can get at things. Like the hoses. My car also has an oil cooler and the pipes are in the way generally, and particularly of the bottom hose. Given the car gets limited use I wonder if the oil cooler is doing anything useful, or worse, when really hot is the oil pump working harder pushing oil through the cooler?
I'm assuming the oil filter head with cooler takeoffs was sourced from another Jag, so if I removed it I'd need to either replace it or blank off the connections. I'm also thinking of fitting a spin off oil filter and have seen the Flexolite product. But if I replace the filter head is there one from a later car (XJ6 S3?) that has the correct pressure relief valve and will fit my 3.8, removing the need for an adaptor?
Should I ditch the oil cooler?
Re: Should I ditch the oil cooler?
the oil-cooler on my car was short-cut (cooler removed) by the last owner and during my last -very hot- trip to Le Mans I had no problems with an overheating car, so I assume you could also get rid of your oil-cooler.
regards, John, the Netherlands
1968 Jaguar S type P1B26363BW ; 1972 Maserati Bora ; 1972 Deutz 4006 ; 1973 Land Rover Series 3 ; 1975 Porsche 911 2.7 Carrera Targa ; 2001 Maserati 3200 GT ; 2004 Porsche Cayenne S ; 2015 BMW 530d Daily Driver; 2009 Suzuki Hayabusa
It is off! And now I can see that the fitting is by way of an adaptor on the filter head, so I should be able to remove this and retain the canister filter. Don't see any point in upgrading to a spin off filter in tha case.
Last 100 Members Who Visited This Topic. Total 7 visits
TimD (1),
cass3958 (2),
nolbry (1),
NigelW (1),
Robman25 (1),
sulzeruk (1)
