ignition coil/ neg/pos conversion
WHEN CARRYING OUT A EARTHING CONVERION, AS A PART OF THIS THE IGNITION COIL WIRES ARE REVERSED, THE COIL MARKED CB- TO DISSTRIBUTER AND IGN TO THE IGNITION SWITCH . AFETR REVERSING, THE IGN IS TO THE DISTRIBUTOR AND CB TO THE IGNITION SWITCH, SIMPLE ENOUGH, BUT IF A COIL IS REPLACED AT A LATER DATE WOULD THE WIRING STILL BE THE SAME .
REGARDS JOHN
1972 ROVER P6
REGARDS JOHN
1972 ROVER P6
Re: ignition coil/ neg/pos conversion
If you replace with a newer coil then the markings will be - (neg) and + (pos), on a negative ground car the -(neg) will go to the distributor.
Thanks for the reply Nigel, I never gave it much thought before, does that mean that the positive and negative coils are different ?.
1972 Rover P6
1972 Rover P6
I'm not sure on that but any coil you get now days have pos & neg markings. How old is the coil on your car?
I changed my car over back in the 1970's when I fitted an alternator and an 8 track stereo.
My car also has been converted and has electronic ignition, the question was due to me reading an article about conversions and I then wondered if the existing coil had to be reversed did that mean any future coil needed to be fitted the same as the original.
1972 Rover P6
1972 Rover P6
I would think any future replacement coil would be fitted the same as the one that came off, inline with the instructions that came with the electronic ignition if you have them.
Last 100 Members Who Visited This Topic. Total 33 visits
Glyn Ruck (1),
badger (1),
RollyTG (4),
KennyL (1),
johngosnell (14),
cass3958 (3),
Jose (1),
sulzeruk (1),
NigelW (3),
David Reilly (1),
Robman25 (1)
