Brake. Pedal adjustment
deelcee
Post by deelcee »
The brake pedal on my 67 s-type is too high
Is there a way to lower it to match the clutch pedal?
jaguar 3.8 s-type mod
lexus ls430
Re: Brake. Pedal adjustment
I have an auto so can't comment as to how to do it on the S Type but with my Lotus Seven I cut and welded the peddles until they suited the heights I wanted them and the correct spacings.
deelcee
Post by deelcee »
Thanks Cass but beyond my capability..was hoping for an easier fix
lexus ls430
HG_S-type
Post by HG_S-type »
Did you check if there is air in the system?
HG P1B9396BW
S-type 3.4 (1968)
XK140 FHC (1955)
E-type S2+2 (1970)
XK8 coupe (1999)
MGBGT (1970)
Freelander 1.8 (1998)
I just checked my 1965 S Type and the clutch and brake pedals are at almost the exact same height. There must be some other cause for yours to be off.
deelcee
Post by deelcee »
No air in the system
lexus ls430
Has the master cylinder been replaced? Could be the wrong one with a longer actuating rod. Can be sorted out with a spacer between the cylinder and the pedal box, this will raise the cylinder thus lowering the pedal.
deelcee
Post by deelcee »
Master cylinder has been replaced
Thanks Nigel I'll get onto it
lexus ls430
At about the same time as your original post, I came across the Pedal Lowering Kit SBS9149 at SNGB completely by chance and I can confirm that it does indeed lower the pedal to an acceptable height. I'd been driving around for 10 years wondering why it was so high! I was able to fit it without disturbing the hydraulics.
https://www.sngbarratt.com/English/#/UK ... SBS9149%60
deelcee (10), RollyTG (1), User avatar jaguar&mg (1), User avatar John Quilter (8), User avatar cass3958 (7), User avatar Orlando St.R (2), HG_S-type (3), User avatar NigelW (3), jerry_hoback (1)
