Greases.
Greases.
I posted this on another forum & feel it is pertinent here.
if you find a sloppy mess in a wheel bearing or wherever it could be due to incompatible greases having been placed/mixed in that hub or component.
Never mix grease types when topping up a hub or other location. Rather clean the bearing & hub & regrease completely. As an example a Calcium Complex grease is completely incompatible with straight lithium greases & will create a runny slop in the hub or other application. Straight Lithium Stearate & 12-Hydroxystearate greases are the most common general purpose greases in an NLGI No 2 penetration on the planet.
See:
Grease compatibility..JPG (88.73 KiB) Viewed 1356 times
Last 100 Members Who Visited This Topic. Total 14 visits
User avatar Glyn Ruck (5), User avatar Orlando St.R (2), Robbo911 (1), IanMac (1), Norton (1), User avatar cass3958 (1), User avatar John Quilter (1), Treetrimmer (1), User avatar David Reilly (1)
