Silencers/Mufflers
Re: Silencers/Mufflers
yes I see what they are doing.
when I bought mine in 2005, shipping was $60. but the mounting kit was included.
Jose wrote: Tue Aug 21, 2018 4:56 pm
I also used Permatex Exhaust Parts Adhesive because I could not find the "FIREGUM" adhesive that they used at the factory.
A factory trained Jaguar mechanic taught me that Jaguar never welded exhaust parts, so I don't.
Jose.....did you use Permatex on the manifold gasket or something else?
Merry Christmas
Merry Christmas Joe !
no. at the manifold gaskets, nothing but the gaskets.
also no sealant wherever there is a donut seal.
only at the muffler to pipe unions and then very little since the band clamps seal well.
Opened my kit the other day and two installation parts were missing and according to SNG, no longer available. Was able to solve one of the missing parts by using a different part that will do the same job. However, I need to find this or its equal:
C.23262 Ring Bracket for Rubber Mountings Plate 74, Part 28. Need two of them.
Any suggestions?????
those are the rear hangers for the rear resonators, right? They are a round steel ring into which a round rubber "donut" with a center hole is inserted.
you might be able to use XJ-6 rear hangers, not sure but they are somewhat similar.
here's a picture of the ones in my S type
Yup, that's it. I will have to look at others.
Thanks
but what is wrong with yours? (assuming you have them).
Also, you might get used ones?
here's a drawing of the XJ-6 rear hanger. But if you have the new rubber "donuts", I would try to find two used brackets.
Joe. Here is one. These things were shockingly made & rusted like hell. Just make up your own & paint properly or powdercoat. You will do a better job. Buy this one as a pattern.
https://www.sportsandclassics.com/parts ... os-c23262/
Exhaust clamp 17 in diagram.JPG (74.92 KiB) Viewed 3097 times
(Ignore this diagram label if it displays. Bracket 17 was one I was searching for at the time)
Don't let anybody sell you this ~ It's wrong. Plus you need the slotted bolt holes in the original for tail pipe alignment.
This is for DS420, MARK 10, 420G C25233
Jose,
Opened my kit the other day and the two C.23262 Ring Bracket for Rubber Mountings Plate 74, Part 28 were missing. SNG said sorry, no longer available in kit. #28 in Glyn's photo.
Glyn,
Bought the last one from sports and classics, we can make two from that example.
Thanks all again for the great help,
Last 100 Members Who Visited This Topic. Total 339 visits
RollyTG (14), Albion (8), User avatar Jose (91), awiedie (3), User avatar cass3958 (33), User avatar Glyn Ruck (49), DevilDog (99), jonesdl (9), User avatar David Reilly (5), User avatar Orlando St.R (9), User avatar NigelW (13), deelcee (4), User avatar Tom Hoffman (2)
