I believe that you are correct. They call it a sealing pad not a seal. I have the old one. It is torn in places and should be able to repair. Have not taken the other off yet. Let me see what the other one looks like. Thanks for the help. It may take me a few days. Cold front moved in. I am in the process of degreasing, etching, and sealing the tanks.
Anyone know where I can find these:
C.11001 Support Block for Clamp #27 in parts catalog under brake controls pages 276-277
C.28976 Shim, under Support Block
C.11002 Clamp, or mounting Servo Unit to Front Wing Valance #28 in parts catalog under brake controls pages 276-277
C.13172 Air Cleaner For Brake Servo (Jag Spares has one for 50 pounds) #29 in parts catalog under brake controls pages 276-277
C11421 Bolt to Secure the Banjo #9 in parts catalog under Reservac Tank for Brake Servo pages 269
C14717 Banjo #7 in parts catalog under Reservac Tank for Brake Servo pages 269
Thanks,
Booster mounts into the front wing. Large removable dimple/cowl screws into wheelarch. Booster/servo has 3 mounting studs on it's round base which bolts to this cover. The cylinder of the booster then mounts to the inner wheelarch with a clamp. All are rubber mounted via grommets.
Position in engine compartment.
Late booster before sending to Barratts for rebuild/exchange.
Mounting clamp for cylinder to wheelarch.
Refurbished booster/servo
Always appreciate your great help.
With regards to mounting the vacuum unit, does it mount on grommets at the rear three bolts as well?
- IMG_0665.JPG (1.32 MiB) Viewed 2369 times
Tom Hoffman (46),
KeithD (2),
jaguar&mg (3),
Glyn Ruck (307),
deelcee (9),
Robbo911 (2),
Harv63 (1),
Fredomusicman (1),
RollyTG (57),
philippe (4),
HG_S-type (40),
abbirkin (12),
John Quilter (70),
Albion (167),
Treetrimmer (9),
cass3958 (267),
Bingo (17),
Orlando St.R (120),
NigelW (40),
jonesdl (35),
David Reilly (18),
DevilDog (628),
Mechiel (34),
Norton (9),
MDLV (1),
SCDaveD (3),
roman_mg (1),
Jim_R (31),
Markunderwood (4),
paddyx350 (21),
johngosnell (6),
wouldbeowner (7),
Sam01 (12),
NWG (8),
JCS (14),
YoungJagFan (1),
pjrjag (18),
Jose (83),
KennyL (1),
maurizio ortodossi (4),
oldirish33 (3),
vaultsman (9),
muzza49 (1),
Horse Power Junkie (1)
