Rear sway bar ?
Bingo
Rear sway bar ?
Post by Bingo »
Will a rear sway bar for a series I or II XKE fit a 64 S type ?
Jim
1964 S Type, 4spd, OD
1988 M6, 5spd
Bingo
Re: Rear sway bar ?
Post by Bingo »
Bingo wrote: Thu Dec 23, 2021 9:15 pm Will a rear sway bar for a series I or II XKE fit a 64 S type ?
Found this….
A key element of the Mark X that Jaguar wanted to include in the S-Type was its sophisticated, and by then widely acclaimed, Jaguar independent rear suspension. The suspension was a revelation at the time of its introduction, and remained the benchmark against which others were judged until the 1980s. Essentially a double wishbone setup, it uses the driveshaft as the upper wishbone. It carries the drive, braking, suspension and damping units in a single fabricated steel crossbridge, which is isolated from the bodyshell by rubber blocks. Including this suspension in the S-Type necessitated the development of a new.
Jim
1988 M6, 5spd
Bingo
Re: Rear sway bar ?
Post by Bingo »
Bingo wrote: Thu Dec 23, 2021 10:07 pm
Found this….
A key element of the Mark X that Jaguar wanted to include in the S-Type was its sophisticated, and by then widely acclaimed, Jaguar independent rear suspension. The suspension was a revelation at the time of its introduction, and remained the benchmark against which others were judged until the 1980s. Essentially a double wishbone setup, it uses the driveshaft as the upper wishbone. It carries the drive, braking, suspension and damping units in a single fabricated steel crossbridge, which is isolated from the bodyshell by rubber blocks. Including this suspension in the S-Type necessitated the development of a new crossbridge suitable for its 54 inches (140 cm) track, coming as it did between the 58 inches (150 cm) track of the Mark X and 50" track of the E-Type.
The S-Type used the same subframe mounted, coil sprung, twin wishbone front suspension as the Mark 2.
Jim
1988 M6, 5spd
Re: Rear sway bar ?
As I understand it the rear suspension on the S Type although derived from the E Type and Mk10 was slightly narrower in width. Not sure but I think the XJ6 again was slightly wider than the S Type. The slightly narrower rear of the S Type was stolen sorry used in the Cobra and Cougar kits due to its width.
That said the sway bar or antiroll bar from the E Type or XJ6 might fit but it would have to be offered up for size to make sure there is no interference with the inside of the rear wheels. Someone must have tried it out before and I am sure others will know more than me.
Re: Rear sway bar ?
And many an American hot rod used a version of this Jaguar independent rear suspension but not sure which width was common. Often extra effort was made to chrome plate each and every part of it for show bling!
Re: Rear sway bar ?
Norman (JCS) is the authority on rear sway bars for S Types. Shoot him a PM. They are available. Not sure if he's fitted his yet. Their size is intermediate to MkX & E Type. All the mounting points are there. Radius arms & body with a plug in them.
JCS
Re: Rear sway bar ?
Post by JCS »
Jim,
“Will a rear sway bar for a series I or II XKE fit a 64 S type ?”
Sorry for the late reply, long term illness and other issues intervened.
I purchased my rear anti- roll bar from HBE Harvey Bailey Engineering in UK, usual disclaimers. Unfortunately, I have not been able to fit it at the present time and quite a few issues need sorting before that time arrives, including Corvid.
My understanding of the Jaguar rear anti-roll bars is that there are three variations to suit track widths approximately 50 inch, 54 inch and 58 inch, for E Type, S type and Mk X chassis types respectively. Therefore I cannot envisage an E Type bar fitting an S Type.
I visited HBE to look first hand at their operation…… for a very small company, I would say very impressive and very knowledgeable. I judge that against most of the smaller automotive operations which I have visited around the world. They have no connection now with the former Rolls-Royce Chief Engineer who formed the company and carried the name.
They are quite leaders in suspension technology and work for most F1 racing teams. Their equipment is the most up to date kit for testing suspension parts, particularly shock absorbers, that I have seen.
On my visit to HBE I learnt a few things about their bars. They advised me, in answer to my many questions, that they cold formed their anti-roll bars, and although they did not say, I would think they might de-stress them after forming.
Our discussions also brought forward another important point. They have come across two different widths between the rear frame section centres, to which the anti-roll bar is mounted, on the Jaguar S Type. In essence that means at least two different side to side distances between the threaded mounting holes. Possibly this was a result of Pressed Steel altering dies to aid body production. Nevertheless, it can, and does raise the need for the user to check the centre lines of the chassis threaded holes before ordering.
I would recommend anyone considering fitting a rear anti-roll bar to check out a few point beforehand, as follows…………
Although I did not fit my rear bar, I did offer it loosely into position. The right-hand side has a few obstructions to consider. The fuel line, brake line and rear brake hose could foul the ends and vertical link on the bar. If these parts have been replaced or re-routed it is even more important to check clearances. Similar fouling problems could just about occur if pattern exhaust silencers and tail pipes are fitted causing possible reworking of another component.
Many of these cars have the rear suspension lower or higher than standard and to adhere to clearances the bar need checking for a foul condition throughout the full suspension travel and full bump condition.
The chassis mounting points take the form of captured threads in the chassis box section, probably even a threaded plate. I do not know if all the S Types were fitted with these threaded mountings from commencement of production. It is worth checking if they are present and just as important rust free.
The anti-roll bar is “U” shaped in the centre to pass around the drive shaft rear coupling, I can see that this might be a hindrance if the axle pinion oil seal needed renewing. I would therefore suggest that the oil seal is replaced if there is any doubt about its integrity before fitting an anti-roll bar.
From memory only, I recollect that the actual head of the special bolt part no. C17149/1 that secures the rear wishbones to rear radius arms, can clash with the anti-roll bar drop link securing nut. In essence these two parts almost “butt heads together” in such a way that only one can be manoeuvred into position and the bolt head is nearly fully recessed…….at least that is my perspective of the arrangement.
In fact, anyone replacing the rear radius arms or bushes may perceive this situation when trying to tighten the self-locking nut on the C17149/1 special bolt. Fortunately, when I had my subframe parts dismantled I found the Jaguar bolt / nut could not be held against rotation. Furthermore, the bolt could be impossible to hold if removal was required with the sub frame in situ.
I overcame that situation by using a top grade 0.5 inch? cap head bolt with some machining to reduce the depth of the internal hexagon. This meant I could hold the bolt head with an allen key and use a wrench on the nut. I mention this arrangement as it would also allow the anti-roll bar link to be attached more easily to the radius arm.
On my car, the right-side chassis section has been repaired at some point in its life, a very good repair it is, but unfortunately the repairer did not reinstate the threaded points for an anti-roll bar mounting. I am very guarded about trying to reinstate any form of mounting in that location, as without very major surgery it will be impossible to reinforce the area sufficient to handle the forces involved.
As I have replaced all the main components on the rear end of my car, including using an E Type 3.3:1 axle ratio, the ride which I value highly is superb and the body roll I can accept for the way I use the car. I initially contemplated fitting the rear anti roll bar out of curiosity rather than necessity, so aborting the fitting is of no great consequent. At the moment outside influences are pointing towards someone in the UK buying a cheap anti roll bar from me, however I hope these notes may help someone who may be contemplating the job.
Bingo
Re: Rear sway bar ?
Post by Bingo »
Thank you.
Your analysis is very helpful. I am going to delay my effort until I have my lift working. At which point in time I will take the measurements you advised and mock up a sway bar to see what issues are present.
Would you elaborate on the the E Type 3.3:1 axle ratio ?
Jim
1988 M6, 5spd
JCS
Re: Rear sway bar ?
Post by JCS »
Bingo
Is there anything specifically you want to know about the E Type axle ratio? For instance, why I chose that 3.3 ratio choice or the actual axle rebuild etc? Would I follow the same route again, any disadvantages etc.
I have had a lift and full workshop facilities for many years and although that makes my jobs easier it sometimes makes it more difficult to explain to someone the intricate details of completing the job without a lift.
I am pleased that you found the information helpful.
Bingo
Re: Rear sway bar ?
Post by Bingo »
Norman,
Why 3.3 and what are the relationships to rpms at typical speeds used in 4th as compared to the stock gearing ?
Did you find usable tourq while In OD in 4th ?
Do you find yourself in 3rd gear more often on backroads ?
Does your s type have the early (pre mid year 1964) rear and Moss box ?
Jim
1988 M6, 5spd
Last 100 Members Who Visited This Topic. Total 65 visits
minimeadow (2), User avatar Glyn Ruck (10), pjrjag (2), User avatar Orlando St.R (2), User avatar John Quilter (10), RollyTG (3), Treetrimmer (7), User avatar cass3958 (9), JCS (11), HG_S-type (1), Bingo (8)
