Air cleaner not horizontal
Jose wrote: Tue Apr 16, 2019 12:25 pm ok, so I couldn't resist to confirm, my spark plug heads are indeed Lucas, not Champion, you guys are confusing me!! :D
One thing I did found out today, the wires need replacing, they actually screw onto the spark plug "heads", their inside is copper wire. The wires are very deteriorated. Also need the hard cardboard Loom through which the wires are routed. It is breaking apart. I don't look forward to this job.
Jose,
Those Lucas plug terminals look like the ones that are correct for my 1956 MGA. After a lot of searching, I managed to put together a set of four NOS ones from Ebay. Here is the MGA Guru article. http://mgaguru.com/mgtech/ignition/ig113.htm
mga spark plug 001.JPG (2.41 MiB) Viewed 3204 times
Glyn Ruck wrote: Mon Apr 15, 2019 8:34 pm
cass3958 wrote: Mon Apr 15, 2019 3:12 pm Love comparing these photos of the engine layouts.
Plug Leads.
Orlando, Glyn and myself all have the plug leads coming from the distributor over the top of the Cam cover whereas Alan and Jose have there plug leads coming up the front of the engine bedside the coil and through the valley of the Cam covers.
I know the reason mine comes over the Cam cover and that is because when I bought new leads thay were quite short even though they were supposed to be for the Jaguar engine and they only just stretch across the top of the cam cover.
So the question is which way should the leads lie?
Both are correct at different times. The sheathed wires & the wires running through circular separators via a chrome ring under the cam cover domed nut into the cam valley wire conduit. My car is set up as original.
The Distributor cap, wires, circular separators, split copper washer end connectors, acorn nuts & Champion Bow Tie plug caps (as Alan & I use & JCNA consider authentic) were sold as a complete replacement set by Jaguar Dealers 25 years ago for S Type & other models under a Jaguar part number.
Early cars did not have engine lifting brackets.
Rob, Further regarding plug wire treatment ~ Orlando has covered the sheath. This is the alternative method used during S Type production.
US engine from a Mk2 of the era.
$(KGrHqN,!rQE88hJMD3cBPYn7wo)J!~~60_57 - Copy (2).JPG (108.67 KiB) Viewed 3201 times
1966 SA car built about 6 months after mine & as mine was originally (This was a concours winner about 20 years before I took this picture ~ now deteriorated.)
Jaguar 3.8 engine 014.JPG (277.66 KiB) Viewed 3201 times
As shown in the S Type Workshop Manual.
Plug wires manual.JPG (124.82 KiB) Viewed 3201 times
Plug lead clip still available.
Plug lead clip.JPG (50.91 KiB) Viewed 3201 times
Plug lead clip C19890 was also used during production
Jose wrote: Tue Apr 16, 2019 1:23 pm ohhh, early production, maybe I should attach the later hoist brackets? my XJ-6 has them. or should I dream about finding the Churchill bracket tool?
can you still get the spark plug wiring Loom thing?
I just looked at SNG and could not find it. Who else might have it? Mine is falling apart if touched.
Jose ~ are you looking for the sheath/sleeve??
Spark plug lead sleeve.JPG (46.69 KiB) Viewed 3197 times
no, that sheath is fine, it is a hard cardboard or similar material "tunnel" through which the wires run to the rear and front. It has a rivetted bracket and the bracket has a foot under one of the D washers. I think it is called a Loom. ??
Alan, yes those look identical to the ones in my S type.
Ah! the conduit ~ also available in red.
Spark Plug Lead Conduit..JPG (42.06 KiB) Viewed 3190 times
Orlando St.R wrote: Sun Apr 14, 2019 6:11 pm One thing that has bugged me for a while is that my air cleaner slopes upwards to the left and touches the under-bonnet sound deadening.
I've been investigating why this might be and here's what I've discovered.
1. The air cleaner mounting bracket was mounted on top of the chrome D-washers.
I have changed this so the D-washers are now on top. It has made a slight difference.
2. My air cleaner mounting bracket looks too new to be original, so I suspect it is an aftermarket replacement. I measured the height at 56.5mm between the points shown in the image. If anyone can be bothered to measure an original, it would be very helpful to know if this new bracket is too high.
3. Actually the engine is not vertical - see level in third pic. The holes for the mounting bolts on the front engine mounts are slotted and both of mine are secured at the extreme ends of the slots. I'm going to get this adjusted when I have the car serviced later this month. I think it needs a hoist to take the weight off the mounts so they can be adjusted.
Any experience in fixing this issue would be gratefully received.
Orlando,
As close as I could measure my original bracket, the distance, compared to yours, is 58.74mm. I have no explanation as to why your filter sits so high. More thought is required.
Great ~ we have 3 brackets the same & I'm sure Rob's will be too. Takes that out of contention.
Thanks very much for going to all that trouble, Alan. It seems as if the answer does not lie in the bracket.
Glyn Ruck wrote: Tue Apr 16, 2019 2:00 pm Ah! the conduit ~ also available in red
Thanks Glyn. Since SNG "improved" their website, I can't find anything !
Last 100 Members Who Visited This Topic. Total 629 visits
User avatar cass3958 (65), minimeadow (1), gripper (1), RollyTG (1), User avatar Glyn Ruck (242), User avatar Orlando St.R (43), User avatar San Jose Scott (1), Albion (7), JCS (36), awiedie (118), johngosnell (6), User avatar Tom Hoffman (5), User avatar Jose (93), jonesdl (5), Motorvated (3), User avatar David Reilly (2)
Users browsing this forum: No registered users and 5 guests
