Does anyone know where these wires go?
Posted: Sat May 20, 2023 8:01 pm
by minimeadow
I was poking around the engine compartment and found these three loose wires tucked underneath the carburetors. Someone wrapped clear tape around them, and labeled them "A/C", so I assume I will eventually need to reconnect them to get the air conditioner working, although that's probably a year or two down the road. They come out of a wire bundle that runs under the glass filter bowl. Wondering if anyone has insight into this. My car has A/C, which I'm guessing was a dealer-installed option.
In the background you can see that I'm part way through replacing the solenoid, unrelated to the current question. I'll post something on what it took to get the car started when I've made some progress on that.
Best regards, Scott
- IMG_3852.jpeg (2.49 MiB) Viewed 5275 times
Re: Does anyone know where these wires go?
Posted: Sun May 21, 2023 10:13 am
Don't know.
I can reasonably say that they are not original wires as the Jaguar loom had bullet connectors not spades and the plastic coated wires look too new. Original wiring was predominately cloth covered. But as you have guessed if this is an optional extra for the A/C then it could have any wire and connectors fitted.
Posted: Sun May 21, 2023 5:10 pm
Not original as Cass says. Might have run to an idle speed booster when the HVAC compressor clutched in??? You will have to trace.
Posted: Wed May 24, 2023 11:42 am
by minimeadow
Cass, Glyn, thank you for the feedback. I'll hopefully come back to this when I get the more immediate issues sorted out. Best, Scott
Posted: Wed May 24, 2023 5:02 pm
Posted: Sat May 27, 2023 3:42 pm
by minimeadow
Cass, thank you for the advice about the felt pad. I pulled it off to see what was behind - fortunately no rust. This car seems to have spent a lot of time baking in the sun, but must have been kept fairly dry.
Posted: Sun May 28, 2023 9:43 am
Three other places to check.
Inside the rear doors where the chrome window channel is bolted to the inside of the door. Here you will find another felt sound pad. Water runs down the channel onto the felt pad and the door rusts from the inside to out. Very common on a Mk2 and S type. One of my rear doors had been "repaired" before I got to it. They had welded in a small square repair patch which had warped the door skin. Took ages to repair this.
- DSCF6704.jpg (3.63 MiB) Viewed 5166 times
The second place is inside the rear wheel arch. On the inside face against the boot wall there are some scallops just like the shape of the bulkhead behind the battery. These retain mud and moisture and you will get rust through this area into the boot. Same as below the dirt and stones get kicked up and damage the paint exposing it to rust.
- DSCF7127.jpg (5.54 MiB) Viewed 5166 times
Lastly the front leading edge of the fuel tanks. All the detritus from the rear wheel gets kicked up into the face of the fuel tank and causes wear and rust. Sometimes the pin prick holes are too small to actually see the fuel leaking but you have a constant smell of fuel vapour in and around the boot.
- IMG_6694.JPG (4.47 MiB) Viewed 5166 times
- IMG_6695.JPG (5.33 MiB) Viewed 5166 times
Posted: Mon May 29, 2023 3:55 pm
The rear door felt patch that pads the bottom of the window channel from the skin is very common. Soak with Tectyl.
Posted: Mon May 29, 2023 10:46 pm
by minimeadow
Cass, Glyn,
Thank you for the rust advice - I will add this to my (growing) list.
Best, Scott
