Dipstick.
Posted: Thu Jul 26, 2018 10:41 pm
Tonight I gave the S Type a quick once over as I have a wedding tomorrow. Pulled the dipstick out to check the oil level and only half of it came out. It appears to have snapped at the top where the solid section goes in to the flexi part. I can see the top of the flexi section in the tube but it is too far down to grab a hold of. I poked it with a rod and it is pretty well solid in place so I am not concerned with it dropping in to the sump but I would like to get it out. Any suggestions?
If I cannot get to it from the top the only other option I have is to drop the sump and get to it from underneath. To drop the sump it is either engine out or drop the front subframe and steering out of the way first. I have a hydraulic ramp now for working on the car so this is not a problem other than time but I would like to get it out from the top if possible.
Then I noticed the brake warning light was on but not the handbrake so checked the reservoir and found it was empty. Leaking out of the bottom again. Poor design on these reservoirs as the plastic bottle gets brittle due to the heat in the engine bay and the tube on the bottom starts to crack and leak if you move it about. Working on the Dizzy recently so had to move it out of the way and it obviously broke then. This is my second in four years. Checked on SNG and they now want £35 for a new one which is essentially a plastic water bottle you can buy in any sports shop for £1. Last one cost £25 so gone up £10 in two years. Repaired for the time being whilst I wait for the new one to arrive.
