CROWN WHEEL & PINION 3.07:1 (14/43
Posted: Mon Dec 23, 2019 5:49 pm
I am just about to advertise a new crown wheel and pinion 3.07:1 ratio. I believe that it is equivalent to part number 8825. It is actually a sort after E Type set. Currently I don't think they are available in UK.
I thought it might interest some one who wants to upgrade a Mk2 or S Type differential, although it is quite a high ratio. Of course if you have an E Type as well as the S Type here is your chance to swap around and sort both cars.
It will not be suitable (without additional spacer/ parts) for upgrading a 3.77:1 differential as the Crown Wheel carrier and bolt set required I believe are different.
In my former life (of retirement) I rebuilt literally hundreds of R-R, Aston and Alvis axles and used gear cutters with the correct Gleason machines. This gear set is one I retained for my use but in the end I have used a 3.3 :1 set in my Jaguar as it has Overdrive.
Asking £550 plus shipping, in UK (no VAT)
