Page 6 of 7
Posted: Thu Nov 15, 2018 7:43 pm
by Orlando St.R
Glyn, do you have/can you post a photo of it in situ, please?
Posted: Thu Nov 15, 2018 8:56 pm
Best I have pre heater box. Moulded pipe. It just pushes on. No clip. Follows the scuttle shape down to under the car. Held by some body tabs. (my car hiding on the right)
- FUJI 64MB 090.jpg (337.98 KiB) Viewed 3420 times
- FUJI 64MB 090.jpg (71.05 KiB) Viewed 3417 times
Tabs:
- 69fdef36_84ce_4cfd_b0c3_3ee242a3d889_c253c0ae7f4a76c90521b7486776bfbee936b318 - Copy.jpeg (111.24 KiB) Viewed 3416 times
Posted: Fri Nov 16, 2018 10:57 am
by Jose
those are the routing tabs. Normally there would be a black nylon sleeve which slips over the tab. Those sleeves were used all the way to 1992, so they can be sourced from XJ.
Posted: Fri Nov 16, 2018 12:27 pm
I used black heat shrink on all my tabs. Works a lot better than that original sleeve & looks authentic.
Posted: Fri Nov 16, 2018 1:01 pm
by Orlando St.R
That's brilliant. Thank you so much, Glyn. Really, really helpful.
Posted: Fri Nov 16, 2018 5:08 pm
It's a pleasure. Will always help if I can. I tried to photograph on my car. Can't get my camera in there for a macro shot or achieve enough contrast of black pipe on dark green paint to be of any use.
Posted: Sun Nov 18, 2018 8:19 pm
by Jose
the black heat shrink tubing is a great idea, Actually yellow would be even nicer.
Trivia: those darned vinyl sleeves were used all the way to 1992 in the Series 3 XJ bodies. I don't know what happened after 1992.
Posted: Mon Nov 19, 2018 1:00 am
Jose wrote: ↑Sun Nov 18, 2018 8:19 pm
You can have it yellow if you wish
- HS100.jpg (64.5 KiB) Viewed 3366 times
Posted: Fri Jan 25, 2019 5:19 pm
by awiedie
Don't know if the issues in this thread have been resolved but here is my input. First, the fume question. I always had exhaust fume smell in the cabin and theorize it comes from the boot area as exhaust gets sucked into the boot past the weatherstripping and forward into the cabin through openings in the rear parcel shelf. I changed my headliner a couple of years ago and the fabric on the back piece around the window and forward on the pieces over the doors was stained with soot in places. I tried to plug as many of the openings in the bodywork as possible before installing the headliner but since I have not driven the car much, I don't know if the problem is solved.
I'm also including a few photos of my scuttle drain pipe that has been discussed. As Glyn says, it comes off the firewall nipple (no clamp) and down to clips on the footwell. It IS close to the exhaust header. I routed mine down between the heater pipes which was about the only available way.
Posted: Sat Feb 02, 2019 11:44 am
by Orlando St.R
Thanks, Alan. That's more or less the routing I used for the scuttle vent pipe, thanks to guidance in this thread.
I agree with you re fumes entering via the boot, as when the boot popped open one day, the fumes quickly became immeasurably worse.
