Refitting the chrome
Re: Refitting the chrome
Some pictures of rivet clips attached to doors. (Mk2)
Door Side Trim Clips.jpg (750.48 KiB) Viewed 2792 times
Love those photos.....keep them coming. Pics are worth many, many words. Do you have other photos??????
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I unfortunately did not photograph fitting chrome to my car but will post reference stuff I find. Most of it is easy going. If you have a sticking point we will figure it out with pics. Kit I used.
Moulding fit kit.JPG (62.36 KiB) Viewed 2784 times
jonesdl
Post by jonesdl »
I seem to recognize most of the kit in the bag are the three brass coloured threaded ones a modification of the front door bolted N/S & O/S and the bonnet/hood one by the Jaguar motive ?. Also are the bonnet/hood side trim folding type clips in the bag as well ?.
I take this kit is from Barrett's.
Thanks again for this information Glyn saves trawling through the various part numbers if all the trim fittings come as a kit which is great nice and easy to order.
Three yellow plated T clips are for front of front door waist trims & trim piece ahead of the leaper.
All bonnet/hood folding tab clips included.
Kit is from Barratts ~ SBS1271FK
Barratts new Website is still a work in progress. If you don't know the P/N you can't find the damn thing anywhere under S Type. I've been paging back through my orders/invoices. I really wish they would leave the darn thing alone. When I made up my order listing I included part numbers & pictures of parts to make identification easier for my restorer. Thank heaven I did that. They have even changed what they call certain parts on the website.
jonesdl
Post by jonesdl »
To be honest I hate using Barratt's for exactly the reason,their web site is a waste of time for the S type not user friendly at all.
Thanks for the kit P/N that will save time.
External chrome finishers & fittings ~ General ~ might be of use to some.
This post will steadily grow ~ please be patient. I will post in sections so if the site drops me I don't lose much data.
External chrome mouldings kit ~ Excludes screen chromes & shoulder chrome beading at winding windows & NDV's (no longer available) ~ a variety of fasteners required to fit.
Screen chrome ~ example & joint cover ~ Glued
Leaper ~ attached with nuts & anti-shake washers
Chrome spears ~ attached with friction bushes
Drip rail joint cover ~ attached with self tapping screw under B Post cover.
B Post cover ~ attached with self tapping screws
B Post moulding ~ Attached with nut & anti-shake washer
Door handle example ~ attached with nuts/machine screws/anti-shake washers
Grill/centre vane/surround & badge ~ attached with nuts & washers.
Headlamp surround ~ attached with self tapping screw.
Sidelamp surround ~ attached with proprietary knurled head chrome screws ~ one long ~ one short.
Indicator lamp ~ attached with 2 brackets, nuts & washers
Wiper Spindle cover, nut & washer.
Windscreen washer nozzles ~ attached with wingnut.
Boot/trunk lid plinth ~ attached with nuts & washers over rubber pads & rubber strip.
1449099649_906704100 - Copy.jpg (19.3 KiB) Viewed 2734 times
Side of numberplate chrome strips/mouldings ~ attached with proprietary plastic clip & speed "nuts"
Boot/trunk lid badging ~ example ~ held in place with friction bushes
Tail lights ~ mounted over foam pads & held in place by nuts & washers.
Example of T Clip used on chrome trim ahead of leaper on bonnet/hood & front of waist trim on front doors.
Example of rivet clip for side mouldings.
Example of tabbed clips for bonnet/hood mouldings.
Foam gaskets for front indicator lights.
Tread Plates ~ attached with self tapping screws.
A Pillar chrome trims ~ tab & glue in place.
Kit did not/does not include friction bushes for spears & badges. Require to be ordered individually unless this has changed. Also latest spears have been produced with threaded studs & nuts. Real dumb as they go into a blind area of the wing. No rear access. Just toss the nuts & use friction bushes as original.
Please consult the Parts Manual for correct washers at all locations as appropriate.
Last 100 Members Who Visited This Topic. Total 925 visits
philippe (32), Sam01 (4), User avatar Glyn Ruck (312), Xroyalnavy (3), Norton (1), Rogerisleofman (1), Fonzie (5), RollyTG (25), Albion (133), badger (1), Treetrimmer (14), johngosnell (7), User avatar John Quilter (9), User avatar cass3958 (90), DevilDog (150), User avatar Tom Hoffman (5), HG_S-type (10), dennis (6), Zephyr12345 (1), User avatar Orlando St.R (28), vaultsman (2), abbirkin (1), jonesdl (32), User avatar NigelW (9), User avatar Jose (38), Motorvated (2), awiedie (4)
