Great comments and photos....thanks.
Now comes the brake and fuel lines.
NOTE:
Mark Underwood's question and replies moved to its own topic at Suspension, Steering & Brakes / Radius arm bushings removal
Moderator
Getting the dash ready.
Albion
Post by Albion »
Great work, well done! I look forward to when I start seeing such results on mine. Noticing the brackets used to mount the wood in place brings to mind that the ones holding the center switch board with the swivel bolts are mounted to the dash by two bolts on either side fixed in place. I noticed that they do not have round holes for the bolts, but square holes. Should there be any bush or anything?
Albion wrote: Tue May 14, 2019 8:27 am Great work, well done! I look forward to when I start seeing such results on mine. Noticing the brackets used to mount the wood in place brings to mind that the ones holding the center switch board with the swivel bolts are mounted to the dash by two bolts on either side fixed in place. I noticed that they do not have round holes for the bolts, but square holes. Should there be any bush or anything?
Could you post a photo of the specific part you are referring to? I looked at my center console and do not see square holes anywhere.
Albion
Post by Albion »
DevilDog wrote: Wed May 15, 2019 1:38 pm
It is the bracket holding the switch board.
Albion wrote: Tue May 14, 2019 8:27 am Should there be any bush or anything?
By the look of it, no. Just a plain washer and a nut.
Albion
Post by Albion »
Thanks.
Concur....washer and nut.
Getting the frames and window installed.....B pillar not attached.
User avatar Tom Hoffman (46), KeithD (2), User avatar jaguar&mg (3), User avatar Glyn Ruck (307), deelcee (9), Robbo911 (2), Harv63 (1), Fredomusicman (1), RollyTG (57), philippe (4), HG_S-type (40), abbirkin (12), User avatar John Quilter (70), Albion (167), Treetrimmer (9), User avatar cass3958 (267), Bingo (17), User avatar Orlando St.R (120), User avatar NigelW (40), jerry_hoback (1), jonesdl (35), User avatar David Reilly (18), DevilDog (628), Mechiel (34), Norton (9), MDLV (1), SCDaveD (3), User avatar roman_mg (1), Jim_R (31), Markunderwood (4), paddyx350 (21), johngosnell (6), wouldbeowner (7), Sam01 (12), NWG (8), JCS (14), YoungJagFan (1), pjrjag (18), User avatar Jose (83), KennyL (1), maurizio ortodossi (4), oldirish33 (3), vaultsman (9), muzza49 (1), Horse Power Junkie (1)
