Air Cleaner
Re: Air Cleaner
David Reilly wrote: Mon Jan 27, 2020 5:25 pm Just a minor point. The original tubes were black .
Interesting David and not disputing that fact as I know your car is all original but the tubes on mine which I assume are original as they came with the car are or were clear plastic tubes. (Discoloured now with age). I can think of no reason why the one previous owner of my car would change them as they do not wear out. Is there a possibility that in later cars, mines as you know is Sept 1967 built, that they changed to clear hoses? Maybe one of the money saving ideas they came up with to reduce costs as rubber was perhaps more expensive than plastic hose.
Re: Air Cleaner
As always....thanks. My car has the nipples...I guess I better find some hoses and clamps.
Thanks again,
Re: Air Cleaner
cass3958 wrote: Tue Jan 28, 2020 12:49 pm
This was typical of the nylon hosing used on SA cars. (aged) ~ Yes I know this pic is in fuel application.
Original fuel hose..jpg (222.74 KiB) Viewed 3692 times
Re: Air Cleaner
I think this may be what is missing. from SNG Barretts
https://www.sngbarratt.com/uk/#!/Englis ... 7a9ca23dea
Re: Air Cleaner
Glyn that is what my hoses look like. Are you saying these are Nylon not plastic?
John the SNG hose you have linked to is the hose that comes from the metal drain pipe for the Scuttle on the bulkhead and allows the water to run down the side of the gearbox. We have mentioned this is a previous topic as we discussed where the line of the hose run should be.
Re: Air Cleaner
looks like I miss read about the air intake hose, I thought it was the scuttle drain hose, so my apologies
John 1B1257BW
Re: Air Cleaner
cass3958 wrote: Wed Jan 29, 2020 12:34 pm Glyn that is what my hoses look like. Are you saying these are Nylon not plastic?
I was always told they were nylon Rob. Today one will just have to use what one can get. (preferably fuel resistant)
Last 100 Members Who Visited This Topic. Total 112 visits
minimeadow (1), Rogerisleofman (1), davinius77 (3), philippe (1), gerrypopO (1), RollyTG (5), JacobusBrinker (1), User avatar cass3958 (16), Treetrimmer (2), User avatar Orlando St.R (3), User avatar John Quilter (7), jonesdl (12), DevilDog (22), User avatar Glyn Ruck (21), johngosnell (10), User avatar David Reilly (5), User avatar Tom Hoffman (1)
