The scuttle vent has been left in place so are they removing this to spray inside? If they removed the scuttle vent they could then remove the vacuum operated switch on the bulkhead to spray behind that and it would give you a chance to polish the switch which comes up nicely. They could also change the vent rubber seal.
The solenoid cover is also in place?.
Lastly they have left the door kickers in place. ie the part that the door closes in to on the chassis. Again why have they done this and with the effort you are putting in these four kickers and the door closers would look great anodised.
Other than those minor points it is great that you have stripped it bare. Too many people respray a car with the engine and gearbox in place or with the doors on so you can't get in behind them to do a good job. Or they change the outer colour and you open a door or bonnet and see the old colour staring at you. Or they hide filler and fiberglass behind new paint work.
Well done Joe in preserving another great S Type. There is another 50 years and more in yours now.
Thanks. The scuttle vent, solenoid cover, and vacuum will be coming off. I have the new rubber for it. As far as the door kickers......I have a call into the shop to discuss. Thanks for pointing these things out to me. I am a rookie and this is my first restoration. Take care.
Putting it back together was obvious when I put mine back in. The smaller hole you have in your photo goes towards the ground and the side of the bush with the larger hole goes to the car and against the rim in the radius arm that stops you pressing it out. I have attached a photo of my radius arms when I had to replace the bushes last year.
You do have to line the holes in the rubber bush up. I think they went side to side as opposed to front to rear unlike the ones in the photo. I think Nigel knows more.
- IMG_1290.JPG (2.31 MiB) Viewed 2933 times
Last 100 Members Who Visited This Topic. Total 2134 visits
KeithD (2), jaguar&mg (3), Glyn Ruck (307), deelcee (9), Robbo911 (2), Tom Hoffman (44), Harv63 (1), Fredomusicman (1), RollyTG (57), philippe (4), HG_S-type (40), abbirkin (12), John Quilter (70), Albion (167), Treetrimmer (9), cass3958 (267), Bingo (17), Orlando St.R (120), NigelW (40), jerry_hoback (1), jonesdl (35), David Reilly (18), DevilDog (628), Mechiel (34), Norton (9), MDLV (1), SCDaveD (3), roman_mg (1), Jim_R (31), Markunderwood (4), paddyx350 (21), johngosnell (6), wouldbeowner (7), Sam01 (12), NWG (8), JCS (14), YoungJagFan (1), pjrjag (18), Jose (83), KennyL (1), maurizio ortodossi (4), oldirish33 (3), vaultsman (9), muzza49 (1), Horse Power Junkie (1)
