Horn no go
muzza49
Horn no go
Post by muzza49 »
I used to have intermittent horn working, but now - nothing.
Have checked the horns and wiring - all ok
There seems to be a white wire going into the steering column, about even with the parcel shelf - not sure if this connects to something to do with the horns ?
Any ideas please ?
Re: Horn no go
My car has no white wire going into the upper column at the parcel shelf level. The attached photo of the upper steering column parts should be of use. The connection is down at the bottom of the column near the floor to a "finger" contact that transfers power to the serrated ring and then up the column on wire (item 38) where this wire has a "tit" contact that grounds the wire when the chrome horn ring or center horn button are pushed. The photo is of a page from the factory workshop manual. The other photos are mine from when I had my column apart.
Column parts #1.JPG (219.16 KiB) Viewed 1698 times
WSM steering colum upper.JPG (370.33 KiB) Viewed 1698 times
jerry_hoback
Re: Horn no go
Post by jerry_hoback »
If it was intermittent before then my first check would be that contact under the horn button. It may have just gotten dirty. Be careful to remove the correct screws, there are 3 that hold the whole thing in and 3 that hold the horn contacts. Those 3 are adjustable and if you set them too close you will get a beep at the slightest touch of the ring. Also definitely check that connection at the bottom of the column. It may have got bumped somehow.
muzza49
Re: Horn no go
Post by muzza49 »
Thanks for the info, will look into all the suggestions...
Last 100 Members Who Visited This Topic. Total 19 visits
member (1), RollyTG (2), jerry_hoback (3), User avatar John Quilter (6), User avatar cass3958 (3), muzza49 (3), User avatar jaguar&mg (1)
