If it's not broke why replace it.
U/J's in half shafts
Springs & shocks
All bearings and oil seals
Lower frame plate
Brake pistons & seals, discs, hand brake components and all pads
Remote brake bleed pipes
Frame mounts & radius arm bushes
Diff (LSD) rebuilt by Alan at AJS Engineering
And a few bits and pieces I've forgotten about.
This was the second rebuild of the IRS, the first was back in 1978 just a couple of years after I got it. It's not a five minute job by any means.
Thanks....advice always welcomed....
The pins on the parking brakes do bend. I found one of mine to be banana shaped when I took it out. I straightened mine but in hindsight should have bought new ones.
Secondly splitting the rear hub from the shaft was not an easy job. I had mine on a bench hitting the end with a hammer and it did not move. I took it to a friends garage who had a twenty tonne press and this finally got the shaft out. Very tight. Not corroded just tight. Also on the outer bearing I found that to remove the inner ring that the bearing sits up against I could not get anything behind the ring to pull it off. See the photo. There is a dust or grease cover which prevents you using a standard puller behind the ring. The only way I could remove this ring was to cut it with a 1mm cutting disc in an angle grinder being very careful not to go too far and damage the spindle. When pressing this ring back on do not push it so far in which will then allow you to tighten it up correctly with the hub nut.
- DSCF9369.JPG (1.59 MiB) Viewed 3381 times
I plan to replace the parking brake pins and pad. Will inspect the caliper to see if that needs rebuilt. Do you rebuild your calipers? My brakes worked fine before take down except for the parking brake. Things may change later, but at this time I do not plan to take the hub apart.
Last 100 Members Who Visited This Topic. Total 2134 visits
KeithD (2), jaguar&mg (3), Glyn Ruck (307), deelcee (9), Robbo911 (2), Tom Hoffman (44), Harv63 (1), Fredomusicman (1), RollyTG (57), philippe (4), HG_S-type (40), abbirkin (12), John Quilter (70), Albion (167), Treetrimmer (9), cass3958 (267), Bingo (17), Orlando St.R (120), NigelW (40), jerry_hoback (1), jonesdl (35), David Reilly (18), DevilDog (628), Mechiel (34), Norton (9), MDLV (1), SCDaveD (3), roman_mg (1), Jim_R (31), Markunderwood (4), paddyx350 (21), johngosnell (6), wouldbeowner (7), Sam01 (12), NWG (8), JCS (14), YoungJagFan (1), pjrjag (18), Jose (83), KennyL (1), maurizio ortodossi (4), oldirish33 (3), vaultsman (9), muzza49 (1), Horse Power Junkie (1)
Users browsing this forum: Ahrefs [Bot] and 1 guest
