heater control reservac tank check valve
badger
Post by badger »
hi all
i have today started this years attempt to get the jag on the road
so all i have left to do is fix an oil leak,replace the sub frame bushes,and plumb the brakes in.
so today i decided to do the brakes and first vacum hose i got to was the one attached to the above
the unit fell in to 2 bits (great).
ive looked on ebay and they want £80 (gulp)
has anyone else replaced one and where did you get it
or has anyone repaired theres i might be able to glue it back together ?
Re: heater control reservac tank check valve
Do you have a photo of the part that has broken in two please then I can look in my box of many parts for you.
badger
Post by badger »
here you go
here you go
jag control.png (202.93 KiB) Viewed 2562 times
badger
Post by badger »
it attaches to the tank in front wing on passengers side
I will have a look over the weekend for you.
Rob. Just be careful not to muddle Brake vacuum valve with heater vacuum valve. They are different. Side of vacuum switch feed does not make any difference. 420 valve is suitable for S Type as confirmed on Barratts page.
Heater vacuum check valve..JPG (38.41 KiB) Viewed 2554 times
Don't know why someone would try and sell a used one for £80 when you can buy new for £60. There is a secondhand one on EBay for £20. https://www.ebay.co.uk/itm/152631714616 ... CEQAvD_BwE
Not going to get to my boxes until tomorrow.
badger
Post by badger »
cass3958 wrote: Sat Apr 24, 2021 8:36 am Don't know why someone would try and sell a used one for £80 when you can buy new for £60. There is a secondhand one on EBay for £20. https://www.ebay.co.uk/itm/152631714616 ... CEQAvD_BwE
not the same the attacment to tank is different
badger
Post by badger »
many thanks for the help the chap with the ebay one for £20 also had the one i required so a deal was done and its on its way to me.
cheers everyone
Last 100 Members Who Visited This Topic. Total 32 visits
Diesel Dan (1), badger (10), User avatar Orlando St.R (2), User avatar John Quilter (3), Treetrimmer (3), User avatar cass3958 (8), Euler (1), JCS (1), User avatar Glyn Ruck (3)
