My car was imported from England. What fuel did they have in England at that time and what was recommended for my car? What I am getting at is that I plan on using Premium Fuel. Do I need to add a lead additive to the fuel?
In the UK now we have 95 Octane which is the normal fuel and a 98 Octane almost equivalent to the old five star both unleaded.
I use the premium 98 Octane fuel in my S type as I have found the cheaper fuel makes the car run on after switching off and with the amount of miles I do the price difference is insignificant.
As for leaded addictives all Jaguar XK engines have aluminum heads and as such have hardened valve seats fitted from the factory. Cast Iron heads where not fitted with valve seats and you used to grind the valve seat in to the cast iron head. Cast iron was softer than the hardened valve seats and the lead was added to to the fuel to lubricate the cast iron valve seats. Unleaded does not affect the valves themselves as these are already hardened.
It does make me laugh when I see a Jaguar up for sale and they state in the advert that the engine has been rebuild at great cost and Hardened valve seats have been fitted as if it did not have them before. So the XK engine has always been able to run on unleaded with no damage caused and do not waste your money asking for hardened valve seats to be fitted as you already have them.
Glyn will no doubt be able to give you more details on the different types of fuel and which is the best to use.
I don't know what pistons you have fitted. Come in 7, 8 & 9 to 1 CR.
I'm sure you have either 8 or 9 to 1 CR pistons & that your cylinder head has been shaved. Most heads today have been shaved.
Just run on the highest octane (AKI in the US) unleaded gas available for the region/altitude you live in/at. XK engines can be prone to knock (pinking, pinging, pre ignition, detonation by whatever name you know it)
Thanks,,,,
Any word from Rob, Rob? LOL
Treetrimmer (14),
RollyTG (28),
Glyn Ruck (301),
BruceK (1),
gripper (1),
jerry_hoback (2),
Albion (44),
gerrypopO (1),
Norton (3),
Euler (22),
JacobusBrinker (5),
MDLV (1),
Cobrasc10 (1),
KeithD (2),
jaguar&mg (7),
JCS (2),
John Quilter (78),
David Reilly (7),
cass3958 (188),
DevilDog (307),
Sam01 (2),
jonesdl (37),
Orlando St.R (22),
NigelW (22),
XKJag (1),
Tom Hoffman (3),
NWG (2),
Motorvated (1),
dennis (1),
Norrena (6)
