Under bonnet insulation
Re: Under bonnet insulation
My main aim is to make the engine more S Type and less noisy/E Type. It shouldn't be as audible in the cabin as it is currently. It's my second S and the first purred: this barks.
1967 MGB
Might that not be just as much down to missing insulation/anti-drum on the bulkhead/floor/tunnel? And/or the routing of the exhaust? And/or the condition of the engine itself?
Re Orlando's comments. Make absolutely sure that all scuttle/firewall, grommets, blind grommets & plugs are in place & in good condition.
+1 to that. There are loads of them, in really obscure places, too. On DG automatics, there is a big one in the gearbox tunnel, too.
1967 MGB
A couple of photos, the new product is the lower ones and seems to look like the original surface finish and is quite stiff this is compared to a standard type of closed cell foam above. It has a denser close cell foam structure and is self adhesive backing also suitable for higher temperatures. It is available by the metre from https://www.campervaninsulation.co.uk I suggest if you are interested in it then contact them direct and have a sample sent mentioning the new under bonnet material suitable for classic cars. I will be ordering enough to do my XJ6 to start with.
- under bonnet liner 1.jpg (685.37 KiB) Viewed 3012 times
- bonnet liner 2.jpg (395.14 KiB) Viewed 3012 times
I wouldn't trust the original material to be fire proof with all the oil that has gone into it over the years.
- flame test.jpg (356.13 KiB) Viewed 3006 times
Is the product actually on the website? If yes, please could you post a link? Thanks.
Last 100 Members Who Visited This Topic. Total 177 visits
Sam01 (1), JAGUARRacing (1), minimeadow (4), UKUSAJag (1), Glyn Ruck (47), Reimbold (1), IanMac (1), Markunderwood (2), RollyTG (9), gerrypopO (1), badger (1), JacobusBrinker (5), KeithD (1), johngosnell (3), Treetrimmer (4), Orlando St.R (23), jaguar&mg (13), John Quilter (5), DevilDog (10), jonesdl (1), David Reilly (1), cass3958 (18), NigelW (15), dennis (1), maurizio ortodossi (3), XKJag (1), Tom Hoffman (1), San Jose Scott (1), Albion (1), deelcee (1)
