BTW, I Say Ding Dong will reproduce a decal (as a sticker) for free if you can show there is sufficient market for it and can send them a decent image and dimensions. They are very obliging.
1. The collar is higher up the intake tube than I've seen on most cars.
2. The hose definitely is on the outside of the intake tube.
3. The hose is shiny (in contrast to mine, which isn't!)
This was an OE pipe shoved up hard but not as far as as the Autocar pic. You can see the collar above it still to be fitted correctly.
This tubing is a lot more shiny & likely a substitute. More course.
There were also a few variations on the Aircleaner shell snout. But not common.
It was 1/2" inch wider in diameter than the 3" inch diameter S type clamp. (3-1/2")
It is also narrower at 1/2" inch as opposed to the S type's 7/8" width.
But it does the same job the same way.
Here it is restored. I found a 3" inch diameter container and used it to reform the clamp, cutting off the excess while copying the one from my car.
If anyone cannot find a clamp, contact me.
It is all in Newsletter Vol 7, No 4 in the Archives.
- NOS and original air intake hoses.JPG (450 KiB) Viewed 3447 times
Last 100 Members Who Visited This Topic. Total 777 visits
Glyn Ruck (186), Rogerisleofman (2), davinius77 (1), David Reilly (15), philippe (3), awiedie (105), Orlando St.R (66), muzza49 (5), Tom Hoffman (10), abbirkin (3), John Quilter (11), Treetrimmer (31), cass3958 (77), ditrc123 (2), Bingo (1), Eddielopez! (1), RollyTG (4), pjrjag (9), JCS (17), johngosnell (19), DevilDog (5), Sam01 (1), khateeb (6), jonesdl (22), NigelW (10), Albion (5), brentpham (10), Jose (120), vaultsman (1), LYD707E (1), trianglefracture (2), nolbry (25)
