But each of the two bolts at the timing cover should have a plain washer and a lock or "star" washer.
The Clamp should have a plain and lock washer at the nut end, and a plain washer under the bolt.
in my car, the Nut was UNDER the clamp, and the bolt head at the top of the clamp. Not that it matters at all.
- s type 004.JPG (2.34 MiB) Viewed 3291 times
- s type 005.JPG (2.13 MiB) Viewed 3291 times
Orlando/Alan ~ Just so I get my order correct. You used 70mm ID convoluted pipe. What length did you order to have sufficient for the job? Did you snip the end that attaches to the air cleaner snout into tabs & alternate folding them internal & external under the Wiedie rubber collar/sleeve or did you just push it (the convoluted pipe) over the snout & attach the collar? I've seen both methods employed & don't know which is original.
![Laughing :lol:](./images/smilies/icon_lol.gif)
the hose goes OVER the metal pipe of the air filter housing, not inside it. It should fit tight enough.
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
I have been told (when I was looking for a replacement hose), that in late 1966 through 1968 production this hose was deleted, but David says there is no Service Bulletin about it, and the parts book does not give any VIN "delete" info. either.
In my car I removed the hose and clamp / bracket. There is an existing hole on the inner wing panel with a rubber plug which I removed to allow cool air into the engine compartment. It is near the intake pipe of the air cleaner. I really didn't notice any performance difference without the hose.
Jose ~ I'm an unapologetic perfectionist & attention to detail has served me well in my career. I establish originality by asking questions when I don't know. Alan has a particularly accurate engine compartment right down to the correct markings on the fan motor & having these sleeves made. Orlando has also helped me with original decal positions etc for RHD so the 3 of us are kindred spirits when it comes to accuracy.
Fortunately my original car had the front bracket & clamp still attached but the pipe & sleeve were missing.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
I'm an unapologetic Driver, I like to use cars, drive them, improve them, the S type and the XJ-6 left the factories with unfinished details, I like to "finish" them.
I like antique cars with modern conveniences.
Last 100 Members Who Visited This Topic. Total 777 visits
Glyn Ruck (186),
Rogerisleofman (2),
davinius77 (1),
David Reilly (15),
philippe (3),
awiedie (105),
Orlando St.R (66),
muzza49 (5),
Tom Hoffman (10),
abbirkin (3),
John Quilter (11),
Treetrimmer (31),
cass3958 (77),
ditrc123 (2),
Bingo (1),
Eddielopez! (1),
RollyTG (4),
pjrjag (9),
JCS (17),
johngosnell (19),
DevilDog (5),
khateeb (6),
jonesdl (22),
NigelW (10),
Albion (5),
brentpham (10),
Jose (120),
LYD707E (1),
trianglefracture (2),
nolbry (25)
Users browsing this forum: Ahrefs [Bot] and 0 guests
