I know the Mk 2's at the Goodwood Revival racing, draw the air for the engine from inside the N/S/F wheel arch via a hose which I have seen when the bonnets are up possibly for the same reason cold air into the inlet manifold ?.
Hope this gives some thought to come forward.
I do have the bracket to reinstall the system on my car, but keep putting it off because it restricts access to the fan belt, dynamo, etc. One day, I'll get round to it. This is the hose I am planning to use: https://www.carbuildersolutions.com/uk/ ... ng-70mm-id I don't have the rubber collar, though. Anyone know where to get one?
Alan Wiedie from this & other forums had some collars made up perfectly to spec. I got mine from him. Will PM you his contact details. He is just trying to recoup his costs.
They are correct black. Just look particularly grey under flash. This is one fitted to his car with a NOS pipe.
Thanks for Alan's contact details. I will get in touch with him.
The illustration at the beggining of this thread does not show the Bracket where the Clamp is attached. ( part number 19 in the illustration).
the Bracket is bolted to the engine block with 2 bolts, and then the Clamp is bolted to the bracket.
Here's the 420 setup, quite similar to the S type's, except for that accordion rubber piece at the front end of the hose.
I strongly recommend people fit the intake hose. While it might not be the perfect cold air inlet it will at least halve the intake air temperature which helps efficiency & lowers fuel consumption. Drawing hot air off of the exhaust manifold is not wise other than possibly in very cold climates at cold start up until engine temperature exceeds ambient temperature.
Looks Great!
Cheers.
Last 100 Members Who Visited This Topic. Total 778 visits
TimD (1), Glyn Ruck (186), Rogerisleofman (2), davinius77 (1), David Reilly (15), philippe (3), awiedie (105), Orlando St.R (66), muzza49 (5), Tom Hoffman (10), abbirkin (3), John Quilter (11), Treetrimmer (31), cass3958 (77), ditrc123 (2), Bingo (1), Eddielopez! (1), RollyTG (4), pjrjag (9), JCS (17), johngosnell (19), DevilDog (5), Sam01 (1), khateeb (6), jonesdl (22), NigelW (10), Albion (5), brentpham (10), Jose (120), vaultsman (1), LYD707E (1), trianglefracture (2), nolbry (25)
