enough is enough Car fumes ?
Glyn, do you have/can you post a photo of it in situ, please?
Best I have pre heater box. Moulded pipe. It just pushes on. No clip. Follows the scuttle shape down to under the car. Held by some body tabs. (my car hiding on the right)
Tabs:
Tabs:
those are the routing tabs. Normally there would be a black nylon sleeve which slips over the tab. Those sleeves were used all the way to 1992, so they can be sourced from XJ.
I used black heat shrink on all my tabs. Works a lot better than that original sleeve & looks authentic.
That's brilliant. Thank you so much, Glyn. Really, really helpful.
It's a pleasure. Will always help if I can. I tried to photograph on my car. Can't get my camera in there for a macro shot or achieve enough contrast of black pipe on dark green paint to be of any use.
the black heat shrink tubing is a great idea, Actually yellow would be even nicer.
Trivia: those darned vinyl sleeves were used all the way to 1992 in the Series 3 XJ bodies. I don't know what happened after 1992.
You can have it yellow if you wish
Don't know if the issues in this thread have been resolved but here is my input. First, the fume question. I always had exhaust fume smell in the cabin and theorize it comes from the boot area as exhaust gets sucked into the boot past the weatherstripping and forward into the cabin through openings in the rear parcel shelf. I changed my headliner a couple of years ago and the fabric on the back piece around the window and forward on the pieces over the doors was stained with soot in places. I tried to plug as many of the openings in the bodywork as possible before installing the headliner but since I have not driven the car much, I don't know if the problem is solved.
I'm also including a few photos of my scuttle drain pipe that has been discussed. As Glyn says, it comes off the firewall nipple (no clamp) and down to clips on the footwell. It IS close to the exhaust header. I routed mine down between the heater pipes which was about the only available way.
- s type scuttle drain hose 004.JPG (2.23 MiB) Viewed 3222 times
- s type scuttle drain hose 002.JPG (2.24 MiB) Viewed 3222 times
- s type scuttle drain hose 001.JPG (1.93 MiB) Viewed 3222 times
Thanks, Alan. That's more or less the routing I used for the scuttle vent pipe, thanks to guidance in this thread.
I agree with you re fumes entering via the boot, as when the boot popped open one day, the fumes quickly became immeasurably worse.
Last 100 Members Who Visited This Topic. Total 334 visits
deelcee (3), Millwind (1), brent (7), awiedie (24), Orlando St.R (42), Tom Hoffman (4), cass3958 (42), Jose (95), Glyn Ruck (44), DevilDog (14), jonesdl (1), David Reilly (2), muzza49 (1), johngosnell (26), vaultsman (16), NigelW (6), maurizio ortodossi (6)
